I have successfully set up the compiling environment and compiled the APJ firmware for the Cube Orange.
Now, I want to integrate the Lua script [copter-deadreckon-home.lua] into the source code. The script is currently located in libraries/AP_Scripting/applets.
Essentially, I aim to compile the Lua script into the source code persistently. Please guide me on how to achieve this.
I’ve observed that someone has successfully implemented this method on another vehicle.
Thanks to everyone for your time, i belive that some one will answer me
Once your vehicle has accepted the apj you’ve build and is flying properly, you can upload your script using Mission Planner :
Config : Full parameter list : scr_enable 1, write params and reboot
Then Config : Mavftp + scripts : put your lua script here
reboot once or twice here and your script will run at start
( You can also embed Lua scripts in the ROM of the chip that will automatically run. Since Lua is currently only run on autopilots with a lot of flash space, they are only restricted in total aggregate size to available free flash memory. Put the scripts in a sub-directory called scripts , i.e. libraries/AP_HAL_ChibiOS/hwdef/OEM_CubeOrange/scripts . Files must end in .lua .)
locating the above path i can’t find but just see [libraries/AP_HAL_ChibiOS/scripts].
so I have to upload the script.lua into this location and then compile the firmware?
I have done one but when I was searching for the parameters like (DR_)
I can’t find them
Those errors you see about /APM/scripts are related to an sdcard probably not present - that is the path scripts get executed if they are placed on an sdcard.
There are two ways to embed the script, taken from documentation
Put it in the hwdef folder of your ChibiOS board definition
Create a folder in the root of your repo ardupilot/ROMFS_custom/scripts and put scripts there
(note the documentation has an error saying you need to put it in ardupilot/build/ROMFS_custom/scripts, but waf expects it to be in the root)
Well, params from the scripts can go missing for a various number of reasons.
Did you test the script runs okay? Is the scripting enabled via SCR_ENABLE?
Add some test messages like gcs:send_text(0, "test log") and check for them in the MissionPlanner messages tab to see if the script is even executed (and look for scripting engine errors there too). Or use SCR_DEBUG_OPTS param to enable some debug logs from the scripting engine.
Also posting a piece of code would help to identify what went wrong. How are you adding the script params?
