I want to load Arducopter on a new Holybro H7 board and I understand the first step is to install the bootloader.
The below wiki below suggests using STM32Cube Programmer.
It just says install it beginning at address 0x08000000.
Do you use ‘Open file’ to select the board xx.bin file and use the above address? i.e., the same process you would use if loading a Arducopter xx.hex file.with STM32Cube Programmer?
yes I choose the firmware with arduxx_with_bl.hex firmware, which includes the bootloader. what holybro H7 are you talking about are you able to get the board into DFU?
Just use the above mentioned route that is linked and make sure and use the xxx_with_bl.hex.
the with_bl means with bootloader so it will install the bootloader and the firmware all in one swoop. after this you will not need to use stm32 unless its the way you want as Mission planner will see it with the ardu bootloader and you can flash firmware from there after this.
