In my 4.0.5 I can enable NOTCH filter with INS_NOTCH_ENABLE but I am not finding any of the commands below:
INS_NOTCH_FREQ
INS_NOTCH_BW
INS_NOTCH_ATT
Is only HNTCH available in 4.0 and NOTCH is gone?
INS_NOTCH_FREQ
INS_NOTCH_BW
INS_NOTCH_ATT
It’s there all right, just set INS_NOTCH_ENABLE = 1 and refresh parameters to see the rest.
Two more points though:
EDIT - Ah I see, slightly customised firmware, OK.
Set HNOTCH to get the peaks with harmonics (where there is a frequency peak, then frequency times 2 peak) then your static notch on a single peak that has no harmonics.
Thank you Shawn - it’s working after rebooting!
I was so sure I did reboot earlier when I could not see those parameters. I must have not…
