Hi
I am having an issue with incorrect time stamps with Plane 4.0.9 and Cube Orange
The setup is Emlid M2 GPS on GPS1 and two cameras an RX1R Mk2 servo controlled and a D4K NDVI over serial on GPS2
Here is the problem the time stamp on the D4K images is always 3 Days behind actual time this error also evident in the Data flash log filename for example today it logged 2021-06-03 instead of 2021-06-06
The RX1R triggers are logged on the Emlid as events this log reports the correct time and date so I know there is no issue with the GPS feed
Any Ideas?
