In the MP Config/Extended config the Rate Roll/Pitch Value D can’t be increased higher than
0.024 manually. With this value on CH6 it’s possible to set it higher. But afterwards not set to the tested value.
Needed for something larger than a Racer.
They upper and lower values are loaded dynamically. Some values are not be loaded correctly and if you change them on the full parameter page then you can adjust them downwards later if need be but the upper values get lost sometimes and default to the set value in error.
Mike
