IMU lag at centrifugal forces
I use the PX to drive a servo gimbal (2 Axis - pitch and roll). I found out that, when the vehicle where it is mounted does curves with “high” centrifugal forces, the gimbal has a huge lag. To verify I put the naked pixhawk in a car and did some fast curves. When I roll the pixhawk during the curve to let´s say 15° roll angle and level it after the curve is finished, it takes maybe 4-5 seconds until the Pixhawk is leveled again on the parameter screen / artificial horizon. This doesn´t happen when the car just drives forward or stands still. I tested with a PX 6C and a PX4. The issue is the same. I assume that this phenomenom produces the gimbals lag as well.
I have no idea why this doesn´t happen when a PH steers a drone plane or copter. Is there any solution on this?
Hope anyone can help
Kind regards
Andreas
Which ArduPilot FW version are you using?
It is 4.2.3. With the newer versions the servo gimbal doesn´t work anymore.
AFAIK it is disabled by default. You need to activate it manually on custom.ardupilot.org and upload that FW to the flight controller.
It might be fixed already in 4.5.5
