I fly in a remote mountainous areas of West Africa.
In using Tower to generate new Spline Surveys,
I am always scared that my flight path is incorrect, for which my 3DR Solo will fly into the mountain (jungle).
Although I often use 3DR Solo App as a reconnaissance flight, the flight has little value because nothing recorded can be transferred into Tower, from where I generate Spline surveys.
It would be fantastic if it were possible to record waypoints while flying using Tower,
or import 3DR Solo Cable-Cam waypoints into Tower;
from where a spline survey can be generated (using Tower App).
I need to be absolutely sure each critical waypoint near the mountain is 20 - 30m above the tree-line
For this, physical flying is the only sure method.
Else, It would be nice if the 3DR Solo App could conduct spline surveys.
Thanks
Alan Seymour
