I am using the latest stable mission planner and I dont see that window. I get a dropdown to select between three compasses… This has always been a bit ambiguous.
It is the preferred solution, suggested by the Developer of Mission Planner all the time, but up to you. You can use the HWID screen to determine which compass Device ID is associated with which bus and then it’s obvious.
