Hi
it’s connect eternal compass, external baro, external gyro/acc to same I2c port on flight controller ?
yes you can get an i2c splitter board that will let you plug multiple devices in.
True but you must check for any address duplication if using two similar devices, two Baro’s or two Compass (even if the FC has an internal) etx: Some have solder links to an alternative.
