Hello. I am using Pixhawk Cube (Black). I am making a plane. I am using an I2C splitter to add an airspeed sensor(MS 4525DO Air Speed Sensor) and an lidar (Benewake TF- Mini Plus). What will be the I2C addresses now for the components ? How to find the new address of each I2C port on the I2C splitter ? I have enclosed a picture of the I2C Splitter I am using
the TF mini plus will need configured to work in i2c mode, I believe Benewake has a program to do it.
Can you please send the link for that ?
The I2C splitter is just a bus extension it has no addressing involved. The devices sit on the bus and each must have itβs own unique address. Unfortunately many mass production devices have a fixed address with no easy way to change them. Others have a jumper pad to set the optional addresses they support. You will have to look at the spec sheets for the devices to find what their addresses are and if you can change them if needed.
Most of the time I2C addresses are unique to an electronic component.
If you have to use the exact same electronic component (same brand, chip, board), the person who designed the board should include some jumper to enable the user to change the I2C address.
So youβre using totally two different components, it will be plug and play
https://www.circuitbasics.com/basics-of-the-i2c-communication-protocol
Thank you very much!!!
can you please say me how did you connect air-speed sensor and TFMINI-S sensors on same splitter can you say me to which ports on splitter did you connect to make both of them to give readings on mission planner
As you can read above this small board is not a splitter it is only a bus extension board. You can use any connector for any device the sequence is not important.
you will need to set the lidar to i2c mode first if you plug it in while in uart mode it will wont work.
I did what all you guys are suggesting but at the end if i plug in both am not getting readings in mission planner whereas if I plugin ay one of the sensor am getting values on mission planner so what might be problem as am using 6port splitter can you guys suggest me to overcome this problem.
I unterstood that you get the readings from both sensors if you directly connect it to the FC but you donβt get the reading if you connect it both at the same time to the splitter and connect the splitterto the FC.
So first test if you get readings if you only connect one sensor to the splitter and connect the splitter to the FC.
Provide information which FC, Splitter and sensors you are using (model, brand, version, link)
