I got the quad plane script to start and I got JSBSim to run Rascal can I make a quadplane in aeromatic++ has anyone done this please help?
Engine Type
in
http://jsbsim.sourceforge.net/aeromatic2.html
" Step 1: The Engine configuration … This step is not necessary if you are using an already existing engine configuration file. In any case you will have to edit the propulsion section of the aircraft configuration file to ensure that the engine name is the same as the name of the engine configuration file. "
only has the options
piston turbine turboprop rocket
not electric but it is shown down below maby simplify the xml output after?
in step 3
Step 3: The Aircraft configuration …
I selected Glider
Number of Engines
4
Engine Type
electric
What does this mean?
Engine Layout
fwd_fuselage mid_fuselage aft_fuselage wings wings and tail wings and nose
The SITL quadplane in ardupilot does not have a xml file I looked.
