I got JSBSim to run the Rascal now I would like to use aeromatic++ to simulate a model quadplane electric any advice or experiences?
I get errors in JSBSim trying to simulate my aeromatic++ defalt plane.
JSBSim --aircraft=my_aircraft --catalog > my_aircraft_catalog.txt
In file aircraft/my_aircraft/my_aircraft.xml: line 105
Tank capacity must not be zero. Reset to 0.00001 lbs!
In file aircraft/my_aircraft/my_aircraft.xml: line 452
Error loading aerodynamic function in aero/moment/Pitch_propwash:
FGTable: row lookup is not monotonically increasing
in row 3 of table in aero/moment/Pitch_propwash:
0<=0
Aborting.
Aircraft aerodynamics element has problems in file Path “aircraft/my_aircraft/my_aircraft.xml”
JSBSim could not be started
FGPropertyManager::GetNode() No node found for propulsion/engine[0]/thrust-coefficient
I tried getting the catalog
I wonder if jsbsim:Rascal>test.txt would output jsbsim to a text file rather than a xterm and let me see a error?
