I downloaded the mission planner simulation and set up the sitl. After doing all the operations correctly, I started the coatcopter.
But I want to open mission planner with plane but I am having a connection problem.
first I write the following command for the connection.
dronekit-sitl plane-3.3.0 --home=-35.363261,149.165230,584,353
Then I try to connect over mavproxy with the command below, but the “mavlink connecting …” warning is always displayed and it is not connected.
mavproxy.py --master tcp:127.0.0.1:5760 --sitl 127.0.0.1:5501 --out 127.0.0.1:14550 --out 127.0.0.1:14551
I ran the same code above on the coatcopter. In the meantime, the Mission Planner application is connected as UDP and 57600.
Where am I making a mistake please can you help?
