I am unable to arm my pixhawk 2.4.8
I tired every possible way but i am unable to arm my pixhawk
  1. Update to Copter 4.5.2 or 4.5.3-beta
  2. What prearm messages do you see in the gcs?
  3. If there are no messages, set LOG_DISARM = 1, try again and upload the log
  4. Upload a .param file with your parameters
  5. What methods exactly did you try?
This isn’t a magic show where you get a miracle answer without us knowing anything about your problem. If you expect a magic show like answer what went wrong, my guess would be “user error”.
If you’ve tried every possible way then something is preventing you. Fortunately in 99% of cases that something is very easily identified by reading the documentation and observing what your autopilot tells you: Pre-Arm Safety Checks — Copter documentation
What you should NOT do is disabling the pre-arm safety checks. They are there for a reason, and your autopilot refuses to arm because something isn’t right that you need to fix.
Hi pixhawk drone is armed but my drone is constantly flipping on backside. I did esc calibration many times but still the problem persists. Please help me out.
Can uu please guide me out where i will get .param file? Is it saved on sd card?
Go to Mission Planner → Config → Full Parameter List. In the top right corner there’s a button “save to file”. This button generates a .param file with all your parameters.
regarding the flipping of the drone:
  1. check AHRS orientation
  2. check motor order and direction in Mission Planner Motor Test
Can u send me .param file so that i can fly the drone safely. I need it for my project submission on 1st june. Please help me out :pleading_face::pleading_face:
Drone specification
Hobbywing xrotor 40A no bec
5010 320kv motor
Pixhawk 2.4.8
Neo m8n ublox gps
13000mah 4s battery
Propeller 15inxh with 5.5 pitch
YOU send the forum YOUR parameter file.
But it’s usually wrong Motor Order and direction from not using Mission Planners Motor Test to determine if it’s right.
The parameter file will not show this but post it anyway.
Every drone is different, you can not take the param file of one drone to fly another.
Even if the Hardware is the same, the accel, gyro, compass, baro, temp calibrations are not.
Flying your drone with the parameter file from another drone is negligent at best and stupidly dangerous at worst.
@Ritobrata_pal use ArduPilot Methodic Configurator software to create the parameter files based on your vehicle components.
Tell ArduPilot Methodic Configurator which components you have, instead of posting them here.
You can’t fly a drone with 15 inch props safely without properly tuning it, and this is a dynamic process where you can’t just hack in a couple of numbers and you’re good. Even when tuned, a drone that size can seriously injure someone or worse, if handled improperly or without safety measures in place.
With smaller whoops I’d say go ahead and learn by doing/crashing, but not in this case.
Full_Parameter List.param (16 KB)
Here is my full parameter list file please check if there are some mistakes, and if possible please correct it.
I downloaded it for the windows but only cmd is opening nothing else do i need to type something?
Yeah that’s right but I badly need help with the settings
Please post a screenshot.
screenshot of what? parameters?
31-05-2024 10:48:08 : PreArm: Compasses inconsistent
31-05-2024 10:48:08 : _MAX)
31-05-2024 10:48:08 : PreArm: Baro: GPS alt error 5793m (see BARO_ALTERR
31-05-2024 10:48:08 : PreArm: Hardware safety switch
31-05-2024 10:47:37 : PreArm: Compasses inconsistent
31-05-2024 10:47:37 : _MAX)
31-05-2024 10:47:37 : PreArm: Baro: GPS alt error 5788m (see BARO_ALTERR
31-05-2024 10:47:37 : PreArm: Hardware safety switch
31-05-2024 10:43:22 : EKF3 IMU1 MAG0 initial yaw alignment complete
31-05-2024 10:43:22 : EKF3 IMU1 tilt alignment complete
31-05-2024 10:43:20 : EKF3 IMU1 initialised
31-05-2024 10:43:20 : EKF3 IMU1 forced reset
31-05-2024 10:42:13 : Frame: QUAD/X
31-05-2024 10:42:13 : IMU0: fast sampling enabled 8.0kHz/1.0kHz
31-05-2024 10:42:13 : RCOut: PWM:1-14
31-05-2024 10:42:13 : IOMCU: 410 2003 412FC231
31-05-2024 10:42:13 : Pixhawk1 001E0031 484E5004 20393455
31-05-2024 10:42:13 : ChibiOS: 6a85082c
31-05-2024 10:42:13 : ArduCopter V4.5.2 (291be848)
there are the gcs log at present
That log is irrelevant. We need a Screenshot of ArduPilot methodic configurator.
Please read my first answer again. And do it
Stop waisting your time. :wink:
