Hunting for lost log data?
I had a bad crash (3.2 rc5) Copter fell from about 100 feet into snow. APM seems to have survived. However, when I tried to pull the dataflash logs, there was no data. No logs were listed. If I try twice, it says error retrieving logs.
I cannot get the CLI to work…the APM seems to be sending data the whole time (it did this before the crash…I think it might have been an update that caused this …).
Is there other way to try to download the data flash or get the CLI working again to try and DL the dataflash through it?
My other though is that then data flash was corrupted when it landed in the snow, caused by water getting on/in the apm when it was still running.
Thanks in advance.
Dave
CLI has been removed for 3.2 to make room for the code.
I assume you are trying to download via dataflash tab in flight data.
[quote=“RabbitStu”]CLI has been removed for 3.2 to make room for the code.
That’s what I thought
I assume you are trying to download via dataflash tab in flight data.[/quote]
Yes…no luck…anyway around it ?
Thanks
-Dave
in that case i dont have another suggestion. Hope you get it sorted. maybe let dry out more if it had snow on it.
