HUD Bad Battery
Hello everyone, MP 1.3.75 I have permanent message on the HUD “Bad Battery”. Battery itself is fully charged ( 12 400 mAh, 22,2V, 6S and connected to POWER2 (Cube Orange, AP 4.0.7). POWER1 - free.
BATT_MONITOR,0
BATT2_AMP_OFFSET,0
BATT2_AMP_PERVLT,39.877
BATT2_ARM_MAH,0
BATT2_ARM_VOLT,0
BATT2_BUS,0
BATT2_CAPACITY,12400
BATT2_CRT_MAH,0
BATT2_CRT_VOLT,0
BATT2_CURR_PIN,4
BATT2_FS_CRT_ACT,0
BATT2_FS_LOW_ACT,0
BATT2_FS_VOLTSRC,0
BATT2_LOW_MAH,0
BATT2_LOW_TIMER,10
BATT2_LOW_VOLT,10.5
BATT2_MONITOR,4
BATT2_SERIAL_NUM,-1
BATT2_VOLT_MULT,12.02659
BATT2_VOLT_PIN,13
Could someone suggest the way to suppress the message?
What are the correct settings for the battery monitor 2 , Monitor, Volt pin, Current pin ?
https://drive.google.com/file/d/1yC5e7Spj1C-yTC2pcjJ-xFmbCwYvnrJN/view?usp=sharing
Bad battery coming from the battery health status bit from sys_status messages.
You can use BATT2 only if BATT is also used. But POWER1 and POWER2 connectors are not related to BATT and BATT2 settings.
Just disable BATT2_MONITOR and SET enable BATT_MONITOR to 4 and set VOLT_PIN 13, CURR_PIN 4.
Very Thanks!!!, now Land - Battery 23,05V 0,3A Cell 3,84V nearly correct. Later will calibrate.
