I get no response when I connect the RCTimer Radio Telemetry Kit 433Mhz to the Huawei tablet, which is on the positive list even with the word perfect attached! I have tried in this order as wcp1947 recommend it.
#1 Power up 3D radio on tricopter
#2 Power up Huawei
#3 with droid Planner installed but not open
#4 Plug in 3d radio (to Huawei) as soon as I plug into Huawei
it ask what program to use [color=#BF0000](it’s here it fail)[/color]. then I start DP
#5 then push connect on Huawei
when I run the app MavLinkHub it says disconnected, when I run Android’s USB Host Controller it says “S3C USB Host Driver NOT found!” and USB Host Check says “Android.hardware.usb.host.xml not found”, “Handheld_core_hardware.xml USB host not enabled” and “Tablet_core_hardware.xml Not found” and when I click on Fix it says "could not start su process"
What do I have to do?
