How to test servos in mission planner?
Reading the following wiki page rover.ardupilot.com/wiki/common-servo/
at the bottom, it says “test that the servos are moving correctly.”
What is the procedure to test the servos?
I can’t find the procedure and I can’t get the servos to move.
T.
@tongbong,
It means to test the servo movement in the Manual Mode with the R/C transmitter on and verify what you see in the Radio Calibration page is what you see when moving the servos in the Manual Mode.
Regards,
TCIII AVd
So I understand that there is no way to trigger the servos directly in mission planner.
