I am trying to stabilize a Vtol to make it stationnairebut it does not work how should I do it ?
Have you tried QLOITER mode?
To make it stationary you would need an accurate positioning system. Probably the simplest to implement is an optical flow sensor in the belly of the aircraft looking downwards.
