My camera is plugged into PixHawk Telemetry 1 serial output channel. I would like to trigger a picture through QGC v3.5.4, but how do I tell QGC how my camera is integrated? If I attempt to manually trigger a photo through QGC’s “Trigger Camera” button in Fly view, QGC gives error message “Camera control command not supported”, presumably because QGC doesn’t “know” who to trigger the camera. I looked at QGC Setup->Camera page, but that only shows parameters for the gimbal axes, nothing about the camera itself. How do I do this?
That is because either ArduPilot firmware or the camera you are using does not support the MAV_CMD_IMAGE_START_CAPTURE command which is being used to trigger the camera. What QGC is saying is basically correct.
Hi, there any remedies for this? Im having the same issue, with my ArduCopter 3.6 created a mission on QGC and trigger camera, but upon upload error occurs.
