I use apm ardupilot flight controller and I faced calibration failed problem in mission planner. This is first calibration test.
You may have to use a version of Mission planner that is as old as that obsolete and no longer supported APM Flight Controller. Suggest you replace it.
APM flight controller won’t support version 3.2.1 later. So I uploaded custom firmware (3.2.1)
Right, obsolete for years.
The problem is not the ground control Station Software on your PC, so I changed the title.
The problem is the since eight years ago obsolete flight controller hardware.
To solve the problem:
- either update the flight controller hardware,
- or downgrade the ground control Station Software (mission planner) to a version from 2015.
thanks I downgrade mission planner version and it worked
