Hello, when I connect the autopilot with the BMSOne to a pc, it always shows 100% of battery remaining, and it decreases from that lineally.
Example: if the real battery capacity was at 50%, it will show 100% on the QGroundControl (QGC), and when the real value is at 25%, the QGC will indicate 50%.
I have also tried to change the mode of the BMSOne from S1 to S0, but it does not work.
At the moment, I can see the voltage of the battery clicking at the percentage symbol on the QGC. ¿Do you know how to change it so I can see it constantly?
Thank you so much in advance!
