I want to use Dual GPS HERE2 with Cune Orange pixhawk.
GPS1 use GPS1 port
GPS2 use CAN1 port
And I can’t push Hardware Safety Switch on GPS HERE2.
But I don’t know which parameters should used in this case.
Please checks my parameter.
Add some boot delay when using CAN devices to allow them to boot up and be functional before the flight controller, 5 seconds recommended but you could experiment with less.
BRD_BOOT_DELAY,5000
Use the MissionPlanner Setup, Mandatory hardware, HW ID screen to check if all devices are detected.
I have just set up parameters but I don’t see internal compass in HW ID.And I can’t calibrate with 3 Mag calibration in calibrate compass process.
COMPASS_USE 1
COMPASS_USE2 1
COMPASS_USE3 1
I have just set up with less BRD_BOOT_DELAY,5000 but I can’t see internal compass.So now i have two external compass.
Do you think it enough for use normally or not.?
