Hello !
I am following these tutorials in order to use a Super Beacon from Marvelmind as GPS:
https://ardupilot.org/copter/docs/common-marvelmind.html
marvelmind_pixhawk_v2016_10_11x.pdf
617.34 KB
PixHawk_Marvelmind_Integration_Manual.pdf
4.23 MB
And I am stuck at Set BCN_ORIENT_YAW. I don’t understand how to read the vehicle’s heading from the HUD .
I’m guessing that the HUD is Mission Planner in my case and the value I need is Yaw(deg) which I can take from here:
But this info is here only when having the drone connected via USB to the PC that runs Mission Planner.
If I stand at the origin holding the vehicle so that it’s nose points towards the second beacon the drone won’t be connected to the PC and I won’t have any info on the HUD, because the origin beacon is not near my PC and it will never be.
Also, there is another way of setting BCN_ORIENT_YAW in one of Marvelmind’s manuals: https://marvelmind.com/pics/marvelmind_navigation_system_manual.pdf
At 9.11. Settings to obtain the correct north direction it says that I can somehow take BCN_ORIENT_YAW as the angle between the Y axis and the real north (while having the lowest address as the origin ), measured manually by me in some way or another.
Following another guide: https://marvelmind.com/pics/PixHawk_Marvelmind_Integration_Manual.pdf
At chapter 9 it describes another way of setting the Yaw.
How do I properly set the Yaw ?
It’s very confusing when there are 3 guides telling you 3 different things.
