How to set tradheli 4.4 for the landing detector works well
I needed to lower all the I terms, as the uav push i terms at full angle before I take off.
So I already exploded one rotor head due to that.
For the moment I use the old ilmi.
below you have log curves of one neer ground flight for test:
I cannot find the takeoff message, only the landed message.
stb col 2 and 3 are set at 40% and 60%.
in stabilized alt flight thrO is arround 55%
II want to test the new I terms H_opt but I need to be sure that the I-terms don’t grow until I really take of.
Why I don’t see the takeoff message ?
Here, the “not landed” flag:
It is not a good practice to takeoff before the run-up completes.
Ok thank you yes I will pay attention on that.
Following this i set the h_option to zero and when I landed in alt mode i pushed the throttle down to land when landed i don’t released immediately the throttle stick to middle and the collective gone to min collective pitch entering the rotor in reonance, I immediately cutted the interlock and the heli don’t broke….
How to avoid that?
How to land safely?
What’s H_LAND_COL_MIN set at?
Normally set this parameter low enough to keep the heli firmly sitting on the skids, but having it set too low can cause troubles. I set this at -2° for symm blades and -3° for asymm blades.
A log where this occurred would help though.
I have asym blades, It’s set to -3 deg, but i set H_COL_LAND_MIN to -1… so I don’t understand. I will send you the logs tomorrow .
