Imozeb
(Imozeb Banes)
September 10, 2024, 5:31pm
1
When requesting GLOBAL_POSITION_INT through MAVPROXY, the data rate is very slow. For example, GLOBAL_POSITION_INT only updates every 10 seconds.
How can I speed up this rate to at least once every second?
I tried to use MAV_CMD_SET_MESSAGE_INTERVAL (Messages (common) · MAVLink Developer Guide ), but it does not seem to work.
Thanks!
snktshrma
(Sanket Sharma)
September 11, 2024, 12:29am
2
Hi @Imozeb ! MAV_CMD_SET_MESSAGE_INTERVAL works indeed! Send what are the values you are setting for the param!
Try running it again with mavlink message ID 33 and interval at 1e6/30 for 30hz rate. It’s working for me
Imozeb
(Imozeb Banes)
September 11, 2024, 10:42am
3
After more testing, it seems like a message backlog issue. Does “recv_match” output the most recent message or does MAVPROXY store a backlog of messages? I’d like the most recent message to be displayed.
PYTHON CODE:
while 1:
ardupilotResponse = mavConnection.recv_match(type = ‘GLOBAL_POSITION_INT’, blocking = True, timeout = 3)
print(ardupilotResponse)
The lat/long stays at a fixed value for about 10 messages and then starts updating normally.
