Hi I am using a radiolink pixhawk on my RC boat and I have two engines and two rudders and I need to make it so on my at9s I can have left engine on ch3 and right engine on ch2 please tell me if there is a way to do it thanks Sam.
if you want it to control the engines independently then just set it to skid steering and use the left and right outputs . If you want them to work in sync, just set both outputs to throttle.
your rudder is setup as ground steering.
https://ardupilot.org/rover/docs/rover-motor-and-servo-configuration.html
Hi I do not want skid steering just separate control on each engine sorry if there was a miss understanding.
so are you wanting to control them independently with dual sticks but not have ardupilot mix them?
you can change it to 2 paddle mode but im not sure if ardupilot will still try and skid steer with it.
you would probably have to make a lua script to custom mix them to another channel.
https://ardupilot.org/rover/docs/rover-steering-input-type-and-reversing-behaviour.html
Thanks for that …,…
