Hi.
I have a mini-goose which has a V tail. In manual mode its very sensitive in pitch but very weak with rudder authority.
I dont want to limit servo throw because this will reduce rudder power.
The mixing gain will increase or decrease both rudder and elevator by the same amount.
I also dont think its a good idea to limit pitch on the TX as other modes are ok in pitch.
Thanks Joerg, I have to say, looking at the explanation in the full parameter list, Im quite confused exactly what that does. Ill try it on the ground tomorrow to see if it has the desired affect.
