I have downloaded the TLOG and other files from the SD card in my flight controller. When I click LOAD in mission planner I see the slider move like it is playing back, but the map is not updated, neither are the flight instruments or anything else.
Is there something I am missing here ? I just want to play back flights that are recorded on the SD card.
Dataflash logs are recorded on the autopilot’s SD card, so they must be downloaded from the autopilot after a flight
Telemetry logs (also known as “tlogs”) are recorded by the ground station (i.e. Mission Planner) on the local PC when the autopilot is connected via a telemetry link
in MissionPlanner, playback is possible for telemetry logs
