how to install firmware i am struggling it failing to download and send failed message. i am trying to spin the motors with rc transmitter and either with mission planner is falling to arm the motors.
may you assisit me maybe the connection setting are not correct. (T10J Futaba transsimitter, mission planner and apm hexacopter drone (Tarot steadii drone mixed parts) ) , futaba receiver R2008SB S-FHSS.
HOW TO LINK THE RC TO THE DRONE, HOW TO ASSIGN THE FUNCTION IN AUX MODE AND HOW TO SWITCH ON THE MOTORS
Hey quick question. Is your servo connector from the receiver going to the RC in on your Pixhawk? I’d check on my radio calibration screen to ensure that I’m getting signal sent to the Pixhawk.
But to arm is typically down and to the right on the throttle side gimbal.
THANK YOU I MANAGED, NOW I NEED ON HOW TO INSTALL FIRMWARE ON MISSION PLANNER, IT HAS THE ERROR,
failed to download new firmware system invalidoperationexception ,THE PORT IS CLOSED, AT SYSTEM IO, PORT SERIAL PORT DISCARDINBUFFER() AT MISSION PLANNER
