You dont edit one normally - but it does tell us details of how the firmware is built for particular hardware.
You could use the BDSHOT firmware if you have BLHELI capable ESCs, and use the RPM data to drive the harmonic notch filter.
But the point was if you were using BDSHOT firmware the RCin pin could be shifted to another location, or in the case of BRD_ALT_CONFIG = 1 certain half-duplex protocols are enabled on the RCin pin, so you probably dont need that - set it to 0 and your receiver should work.
Status report:
Firmware = KakuteH7
BRD_ALT_CONFIG = 1
PreArm: RC not found
Firmware = KakuteH7
BRD_ALT_CONFIG = 0
Firmware = KakuteH7-bdshot
BRD_ALT_CONFIG = 1
BRD_ALT_CONFIG = 0
ESC: Iām using the tekko32 f4 65a that came with the FC. The product description page says it comes with BLHeli_32 firmware and supports Dshot, so thatās the firmware I ought to have been using in the first place. But while this is a step in the right direction, it still doesnāt see the Rx.
I dont see an issue with your parameters - but I could have missed something.
How are the receivers connected to the FC? Serial 6 Rx pin to Tx pin of receiver, and Serial 6 Tx pin to Rx pin of receiver
Yes. Exactly that. Also I experimented with switching them when I was testing out 3 different receivers, Tx to Tx and Rx to Rx, just in case I or the manufacturer had gotten something backwards. But that didnāt work either.
edit: Just to be clear I initially (and still have) it set up with the receiver Rx to 6Tx on the FC, and receiver Tx to FC 6Rx. But I tried it backwards, too.
I promise to stop derailing your blog post after this. But I got the FC to talk to the RC.
I donāt know about you but I was expecting to find a hardware issue. Instead itās working but I still donāt know where the problem is.
@amilcarlucas
Thanks for the excellent configuration guide. The parameter update and change tracking method is very helpful.
A couple of questions on the build list if I may?
The H-RTK F9P GNSS looks quite large for the copter size and the helical antenna could be very vulnerable to impact damage. The location also sacrifices the GoPro mount.
Was this unit and location chosen for demonstration purpose vs an end mount GPS?
Concerning the battery, was this mounted underneath and was the PM02 V3 Power Module hard wired onto the FC?
I hope you can help?
Nice video, I will add some of the stuff you did (for example 4KHz IMU samplig on Matek H743 Slim) to the files. Thanks.
If you do a part 2 video with the first flight and the autotune, please show and use the provided .param files. They simplify and speed up the configuration process.
