I am trying to configure my Pixhawk FC to allow me to control an onboard camera to take a photo or to start/stop a video recording.
The camera is a Hawkeye Firefly 6S and it has a remote control board connected to the USB port. This remote control responds to PWM signals from a receiver channel:
1000 uS is to take a photo
1500 uS is no action, stop recording
2000 uS is to start recording a video
I have configured a 3-way switch on my transmitter to output those 3 values on Channel 8 – UP is 1000 uS, CENTRE is 1500 uS and DOWN is 2000 uS.
Now, what do I need to do to get the Channel 8 PWM signal to appear on one of the 6 AUX Ports (AUX1-AUX6, referred to as RC9-RC14 in Mission Planner) of the Pixhawk, so I can connect the Firefly 6S remote control signal wire?
I guess I need to configure ArduCopter to convert the Channel 8 PPM signal to the equivalent PWM signal and map that signal to one of the AUX ports as if there was a servo connected to that port.
Could someone please point me to the parameter/s that I need to configure to achieve the above?
OK, I think I have figured it out, but I still need to test it.
BRD_PWM_COUNT is set to 4 by default, so AUXOUT 1 to 4 are PWM outputs.
If I set SERVO9_FUNCTION=58, then RC channel 8 should be passed through as a PWM output on AUXOUT1.
Thanks for that advice Mike - I had no idea that the safety button also inhibited the AUX outputs. I would have been really puzzled trying to get it to work otherwise. And thanks for the link to your article - it is very informative.
And the good news is that my theory was correct - it all works as expected. I can now take a photo or record a video from the Firefly camera on my hexacopter …
Sorry, I can’t answer that question - I only know that it works with the Firefly 6S.
There is a huge choice of suitable Tx and Rx available and your budget and local RF rules will help you narrow down the options. If you want to view the video within your GCS, then you will need a Rx that outputs in UVC via USB - the Eachine ROTG01 is the one I use.
I will oreder and test the cable on my firefly 6s…i will check for a good scheme for connect the firefly6 to the module for transmit the video on GCS…will not be easy
I am using the Eachine ATX03 on the hexacopter as the video transmitter and the Eachine ROTG01 as the receiver connected to the GCS. Eachine have a good range of suitable Tx and Rx video modules to choose from.
