Hi everyone,
I’m currently working on creating a plugin for Mission Planner where I need to overlay a text box rectangle on the right side of the GMap. However, I’m facing an issue where the text box moves whenever I zoom in or out, although the view area center point is not changing. if I drag the screen, text box is on the right side well.
I have inherited the GMapOverlay class and created a custom class to draw the rectangle using the OnRender method. Here is a snippet of my code:
public class MyOverlay : GMapOverlay
private GPoint mapBottomRightGPoint;
private PointLatLng mapBottomRightLatLng;
private GPoint mapBottomRight;
private RectangleF rect;
private int text_box_width = 100;
private int text_box_height = 380;
private GMapControl MyFDGMapControl;
private GPoint _previousCenter;
private long deltaX = 0;
private long deltaY = 0;
private static long deltaX_accumulated = 0;
private static long deltaY_accumulated = 0;
public MyOverlay(GMapControl FDGMapControl)
MyFDGMapControl = FDGMapControl;
//FDGMapControl.OnMapZoomChanged += GMapControl_MapZoomChanged;
//FDGMapControl.OnPositionChanged += GMapControl_PositionChanged;
private void GMapControl_MapZoomChanged()
private void GMapControl_PositionChanged(PointLatLng point)
public override void OnRender(IGraphics g)
base.OnRender(g);
mapBottomRight = new GPoint(Control.Width/2, Control.Height/2);
RectangleF rect = new RectangleF(mapBottomRight.X - text_box_width, mapBottomRight.Y - text_box_height, text_box_width, text_box_height);
Color lightGray = Color.FromArgb(128, 211, 211, 211);
using (SolidBrush brush = new SolidBrush(lightGray))
float radius = 10f;
GraphicsPath path = new GraphicsPath();
path.AddLine(rect.X + radius, rect.Y, rect.X + rect.Width - (radius * 2), rect.Y);
path.AddArc(rect.X + rect.Width - (radius * 2), rect.Y, radius * 2, radius * 2, 270, 90);
path.AddLine(rect.X + rect.Width, rect.Y + radius, rect.X + rect.Width, rect.Y + rect.Height - (radius * 2));
path.AddArc(rect.X + rect.Width - (radius * 2), rect.Y + rect.Height - (radius * 2), radius * 2, radius * 2, 0, 90);
path.AddLine(rect.X + rect.Width - (radius * 2), rect.Y + rect.Height, rect.X + radius, rect.Y + rect.Height);
path.AddArc(rect.X, rect.Y + rect.Height - (radius * 2), radius * 2, radius * 2, 90, 90);
path.AddLine(rect.X, rect.Y + rect.Height - (radius * 2), rect.X, rect.Y + radius);
path.AddArc(rect.X, rect.Y, radius * 2, radius * 2, 180, 90);
path.CloseFigure();
g.FillPath(brush, path);
//creat color for font
Color modifiedDarkGray = ControlPaint.DarkDark(Color.DarkGray); // get a darker version of DarkGray
float brightness = 0.2f; // increase brightness by 20%
float saturation = 0.3f; // saturation at 0 firstly(grayscale)
float hue = 0.3f; // keep hue at 0 (gray)
float alpha = 1.0f; // keep alpha at 1 (opaque)
modifiedDarkGray = FromAhsb(alpha, hue, saturation, brightness);
// Add text to the rectangle
using (Font font = new Font("Arial", 12))
using (SolidBrush textBrush = new SolidBrush(modifiedDarkGray))
string text = "Control Position : " + Control.Position + "\n" + "Control Width : " + Control.Width + "\n" + "Control Position To GPoint : " + Control.FromLatLngToLocal(Control.Position)
+ "\n" + "Visible Area : " + Control.ViewArea;
SizeF textSize = g.MeasureString(text, font);
PointF textLocation = new PointF(rect.X - text_box_width, rect.Y - text_box_height);
g.DrawString(text, font, textBrush, textLocation);
I tried to use offset value from center like this code below, but it didn’t worked. :
base.OnRender(g);
// Get the current center point in pixel coordinates
GPoint currentCenter = Control.FromLatLngToLocal(Control.Position);
// Calculate the difference in pixel coordinates between the current and previous center points
deltaX = currentCenter.X - _previousCenter.X;
deltaY = currentCenter.Y - _previousCenter.Y;
// Calculate the position of your rectangle based on the size of your rectangle and the offset
float rectWidth = 600;
float rectHeight = 680;
GPoint rectPosition = new GPoint((Control.Width / 2), (Control.Height / 2));
//GPoint rectPosition = new GPoint(Control.Width - rectWidth, Control.Height - rectHeight);
deltaX_accumulated += deltaX;
deltaY_accumulated += deltaY;
rect = new RectangleF(rectPosition.X + deltaX_accumulated - rectWidth, rectPosition.Y + deltaY_accumulated - rectHeight, rectWidth, rectHeight);
_previousCenter = currentCenter;
// Custom rendering logic here
float radius = 10f;
path.CloseFigure();
PointF textLocation = new PointF(rectPosition.X + deltaX_accumulated - rectWidth, rectPosition.Y + deltaY_accumulated - rectHeight);
Thank you in advance for any help!
