I am running AP v4.1.7 in 2 planes. One plane has much less deflection than the other, and the P,I,D and other relevant param are more or less the same. I went thru all the answers/suggestions to the posts similar to my issue , but all those answers did not help…the answers/suggestions include :–
- Is air speed sensor installed ---- mine is not
- Scaling _speed — at default of 15 (no change in aileron deflection when set to 0 or 50)
- Stall prevention — no change in aileron whether activated or not
- Change in throttle position does not change aileron deflection.
- Lim_ROLL_CD ---- I change to max of 9000, no change in deflection, whether rolling the plane or using Tx aileron stick.
I am concerned about this small deflection, and thus in Manual mode, I increase the aileron deflection for next flight, just in case. Why one plane has more deflection than the other, and which param controls it ?
Can anyone help ? Thank you.
