I have got a pixhawk lite FC and a Frsky L9R receiver which outputs an analog voltage in the range of 0-3.3V to indicate the RSSI. I have checked with a multimeter that the RSSI output of the receiver is working
I have done all the procedures in this webpage http://ardupilot.org/copter/docs/common-rssi-received-signal-strength-indication.html The RSSI signal is connected to the S.Bus port of the pixhawk. The parameter settings are RSSI_PIN = 5 and RSSI_RANGE=3.3 as indicated in the webpage but I did not get any RSSI text in the flight data screen of Mission Planner at the location indicated below :
In the “status” window of the flight data screen of Mission Planner, the value of the rxrssi parameter is zero. May I know if there are anything that I have done wrong ?
Also. Did you add the filter resistor and capacitor as described in the link? The Receiver actually outputs a digital signal using Pulse Width Modulation. The RC Low Pass Filter smooths out the input pulses to produce a reasonably smooth analog output, to be read by the Pixhawk
This is a step that some people trying to use the FRSky RSSI miss.
