note that these are recommended max, but there is nothing magic about the value. If you find it works well with a larger value then let me know.
Tridge,
From the documentation, I assumed (incorrectly) that the max D-term value was an enforced maximum.
Is the max P term the same (i.e., can it be set to a value higher than 10)?
If so, I might try adjusting both a bit higher.
The current settings works well âwithin limitsâ. If Iâm starting in a straight line or from rest, the controller seems to be able to keep the plane going straight. But if I throw it off by steering manually into a curve and then let it go back to automatic mid-turn, it doesnât converge very fast (if at all).
it can go as high as you like. If you find you need much higher values then I may raise the advertise maximum for a future release.
Cheers, Tridge
I want to use differential thrust for a VTOL tiltrotor. But I already assigned motor1 and motor2 (33,34) using the SERVO_(1 and 2) FUNCTION . Is it possible to have differential thrust in the plane mode FBWA?
I am using a tilt-rotor as well. Would be interested in hearing the answer to this question.
The easiest way to get your planes to turn tighter is increase LIM_ROLL_CD or NAVL1_LIM_BANK.
Also decrease NAVL1_PERIOD.
