Hi. I’m turning my sea kayak into a USV Hydrographic Survey Boat. The autopilot is a Pixhawk 3 Pro. I have a PC onboard running Hypack to collect the hydrographic data. I have used MissionPlanner to calibrate the radio (Taranis X9D Plus/X8R). I have calibrated the radio channels, and have channel1 enabled as Rudder and channel 3 as Throttle (in Config/Tuning/Standard Params). But when I go to Initial Setup/Servo Output, nothing happens.
How do I enable the Servo Outputs ?
Best Regards
Bo
