I noticed in the Adding an Optical Flow Sensor section (right below Adding a Rangefinder) there’s reference to setting a parameter that enables the optical flow sensor.
Is it possible that there is something like that required to enable a rangefinder?
If a Lightware LW20/C (I2C connection) isn’t supported, the analog rangefinder will likely suffice for my purposes using the simulator.
Thanks Mustafa - I appreciate the suggestion. I’m not sure I can translate that reference from MavProxy to Mission Planner SITL. If you like, I’ll let you know if I figure it out.
MAVProxy can be installed to Windows, too.
But I don’t think you had to had that since you need to run sitl “exe” with some arguments to use USB as serial device.
Anyways, probably Windows will make you hit some walls on the port part.
I really recommend you to work on Linux.
You need to use the serial connection of the rangefinder and a UART adapter to connect to the PC.
Good luck…
Most of my LINUX work has been limited to creating LAMP stacks for Wordpress - running on a DigitalOcean droplet.
I do have a Raspberry Pi-4 that I could boot up.
I guess there’s AUX on my MACs - I’ve set up LAMP stacks on that too.
I can do the I.T. stuff - but my goal is to fly sUAS - I don’t want to do any more I.T. stuff than absolutely necessary.
There’s this weird grey area where software engineering touches sUAS operation within the ArduPilot sphere. I get the impression that the folks who write ArduPilot code have the notion that people operating ArduPilot drones should be willing to get into the code too. I will if I have to - but it’s a major detractor of the time and energy I have to learn how to use ArduPilot in a productive way.
It’s a good things that fellows like you are willing to help bridge the gap - thank you - your efforts are appreciated!
