Hello, I am configuring a fixed-wing VTOL tilt-motor and notice that the conventional fixed wing control surfaces are also active while in VTOL flight modes. This creates instability in all conditions where the aircraft is not in headwind while in VTOL mode since the controls will be reversed, and hence I would like to deactivate the control surfaces while in all VTOL modes. I would like them to activate during transitions (Q_Assist) and Forward Flight modes.
Could somebody please instruct me on how I can achieve this? Thanks!
If the AIL, ELE and RUD are on separate radio channels, you may try setting a channel override in your control radio.
Takeoff in QHOVER (? - it’s been a couple of years since I tried VTOL planes) and have the channel overrides set to 1500 - neutral for AIL, ELE and RUD and active when the flight switch is QHOVER.
When you start the transition, set the overrides to turn OFF when you select FBWA/B and your aerodynamic control surfaces will be active again.
I am having the same issue with my Tilt rotor VTOL; in Q_ modes, the ailerons and elevator still respond to rc input (the rudder however does not!).
This is not good in forward flight in Q_modes, as when pushing forward on the stick the elevators are trying to push the nose down, causing the front motors to work harder then necessary.
Would it be possible to have a Q_OPTION to disable control surfaces in Q_ modes?
Looking at this thread, the required behaviour already exists to some extent in Tailsitters.
Maintaining control of Flaperons in my case would be useful.
