Hi, I am trying to use the parameters from the JSBSIM engine and create a telemetry log file so i can visualize the aircraft in Mission Planner or UAV log viewer. Altough I am doing this in Python, I would like some help on creating this file.
This is my code:
def observations_to_tlog(observations, timestep_sec, output_file):
Converts an episode’s observations into a .tlog file.
Parameters:
observations (list): A list containing observations for the entire episode.
timestep_sec (float): Time interval between observations in seconds.
output_file (str): Path to save the .tlog file.
Returns:
None
with open(output_file, 'wb') as tlog_file:
mav = mavlink.MAVLink(tlog_file)
mav.srcSystem = 1 # System ID
mav.srcComponent = 1 # Component ID
current_time_ms = 0 # Time since start, in milliseconds
step=1
for values in observations:
current_time_ms += int(timestep_sec * 1000) # Add timestep in milliseconds
# Extracting the values from observation
current_roll = values[0] # Roll in radians
current_pitch = values[1] # Pitch in radians
current_yaw = values[2] # Yaw in radians
current_altitude = int(values[4] * 1000) # Altitude (AGL) in millimeters
current_altitude_msl = int(values[8] * 1000) # Altitude (MSL) in millimeters
current_lat = int(values[9] * 1e7) # Latitude in 1E-7 degrees
current_lon = int(values[10] * 1e7) # Longitude in 1E-7 degrees
velocity_north = int(values[11]) # North velocity in cm/s
velocity_east = int(values[12]) # East velocity in cm/s
velocity_down = int(values[13]) # Down velocity in cm/s
ground_speed = int(values[14]) # Ground speed in cm/s
heading = int(values[15]) % 36000 # Heading in centi-degrees
roll_speed = values[16] # Roll rate in rad/s
pitch_speed = values[17] # Pitch rate in rad/s
yaw_speed = values[18] # Yaw rate in rad/s
# Sending HEARTBEAT message every 5 steps
if step % 5 == 0:
heartbeat_msg = mavlink.MAVLink_heartbeat_message(
type=mavlink.MAV_TYPE_FIXED_WING,
autopilot=mavlink.MAV_AUTOPILOT_GENERIC,
base_mode=0,
custom_mode=0,
system_status=mavlink.MAV_STATE_ACTIVE,
mavlink_version=3
mav.send(heartbeat_msg)
# GPS_RAW_INT message
gps_msg = mavlink.MAVLink_gps_raw_int_message(
time_usec=current_time_ms * 1000, # Time in microseconds
fix_type=3, # 3 = 3D Fix
lat=current_lat,
lon=current_lon,
alt=current_altitude_msl,
eph=50, # Horizontal dilution (cm)
epv=50, # Vertical dilution (cm)
vel=ground_speed, # Ground speed (cm/s)
cog=heading, # Course over ground (centidegrees)
satellites_visible=10 # Number of satellites
mav.send(gps_msg)
# ATTITUDE message
attitude_msg = mavlink.MAVLink_attitude_message(
time_boot_ms=current_time_ms, # Time in milliseconds since boot
roll=current_roll, # Roll in radians
pitch=current_pitch, # Pitch in radians
yaw=current_yaw, # Yaw in radians
rollspeed=roll_speed, # Roll rate (rad/s)
pitchspeed=pitch_speed, # Pitch rate (rad/s)
yawspeed=yaw_speed # Yaw rate (rad/s)
mav.send(attitude_msg)
# GLOBAL_POSITION_INT message
position_msg = mavlink.MAVLink_global_position_int_message(
lat=current_lat,
lon=current_lon,
relative_alt=current_altitude,
vx=velocity_north,
vy=velocity_east,
vz=velocity_down,
hdg=heading
mav.send(position_msg)
step+=1
print(f"TLog file successfully created: {os.path.abspath(output_file)}")
