Hi to all,
I’ve bought these radio modules:
The problem is that the connector from the radio module only has 4 wires (GND, VCC, RX, TX) and it doesn’t match the connector TELEM1 on my pixhawk.
What should I do in this case?
I checked the telem1 port pinout and it says:
VCC
TX
RX
CTS
RTS
GND
Should I connect the RX from the radio module to Pin 2 on TELEM1 port and TX from the radio to Pin 3 on TELEM1 port?
dkemxr
(Dave)
December 21, 2021, 6:16pm
2
Right, and VCC and GND, ignore CTS/RTS.
Thank you! I’m going to make a custom connector so I can plug in into the telem1 port by usign GND, VCC, TX and RX.
Dave84
(David )
December 22, 2021, 4:59pm
4
Your telemetry don’t have the flow control…,but you can find also some telemetry module that support flow control.
Telemetry with control flow offer more performances
Thank you for the advice!
