How to control thrust percentage based on pitch values
I am flying my drone in ‘guided’ mode and we can control the drone based on it’s attitude i.e roll, pitch, yaw and additionally thrust percentage. I am trying to control the landing sequence for a FW/VTOL through the guided mode.
I’m varying my roll,pitch,yaw values based on the landing location w.r.t drone’s location
while testing in SITL I noticed that thrust percentage was controlling both airspeed and climb-rate (we can’t control these speeds directly) and it’s also depending on the pitch angle (dive angle) of the FW/VTOL calculated as per the movement
can anyone help me out how I can give the thrust percentage based on my pitch values such that I can replicate a smooth landing sequence.
this is something I’ve tried so far any additional suggestions will be appreciated
I am also assuming a linear relationship between Thrust airspeed and climb rate since I’m in simulation
             Kp_th = 0.02
            # defining a trajectory speed
            trajectory_speed = 25
            vrt_speed = sin(pitch_angle)*trajectory_speed # climb rate
            # throttle percentage for both
            T_airspeed = trajectory_speed/  Kp_th
            T_climb = trajectory_speed/(Kp_th* sin(pitch_angle))
            thrust_value = max(T_airspeed, T_climb)
            # saturating thrust value within the range 0-1 as per limit
            thrust_value = max(0.0, min(1.0, thrust_value))
           # attitude is commanded through
           await (set_attitude_target(roll = (roll_corr), pitch = (pitch_angle), yaw = (yaw_angle), thrust =  thrust_value))
