I have two servos which should move in sync. How I should connect them to matwk f405 FC to make them on one channel? Apart from that where I should solder them. It is very new topic for me. I have never worked with servos
you may need connect them together in physical. i suspect
If the servos should always move in sync, then you simply solder their wires together or use a Y-lead, and connect them to the appropriate channel depending on their function.
Or you can connect them to different servo outputs and assign the same SERVOx_FUNCTION
to them. A possible benefit is that they may be trimmed differently, which may be useful if you need to configure movements of different magnitudes.
