Greetings!
My hexacopter is built for agriculture purposes. Now I need to attach a flowmeter whose job is to stop the pump when the tank which contains the liquid becomes empty. I have connected the flowmeter to AUX4. But i dont know what are the changes i need to make in the parameters.
FC: Pixhawk orange cube plus
You suggestions would really be appreciated. Thanks!!!
Yes i did and i followed the procedure mentioned in it. The good news is that im able to read the flow meters value and thats it.
What i want is when my 10L tank gets empty, it should trigger a fail safe but i dont know how to do this. Any suggestions?
No sir I’m not using a companion computer. I’m making this copter for a client of mine. If i add a companion computer, it would unnecessarily complicate it for him.
yes i did. I gave battery monitor as 11 and it works fine. The flow meter is working and I’m able to read the values as well. But what I need is that after the tank gets empty, my pump should turn off and rtl should get triggered. Is there any parameter i can change to achieve this?
Yea, that is fine but how to turn off the pump. Im allowed to use lua script here. I need to make some changes in the source code and build a new custom firmware
