How should SimpleBGC set up?
PIXHAWK how to set up?
Using MAVLINK?
Hi Adam,
Randy wrote a guide in our wiki: http://ardupilot.org/copter/docs/common-simplebgc-gimbal.html I hope it’s helpful.
Thank you, I will try to set up
According to the guidelines of the wiring, AlexMos USB will not be able to connect, do not know why?
I’m not sure what you mean. What do you want AlexMos USB for?
controller USB port can not connect with SimpleBGC_GUI
Disconnect the Telemetry ports can be used normally USB ports
Maybe they share the same serial connection, I have no idea.
