How to configure PWM signal to AUX out on Herelink?
Hi Everyone!
I’m trying to set my herelink’s camera button to send a PWM signal to one of the aux outputs of the herelink air unit, so I could start a PWM-based motor, but whatever I do, or try, I can not find the solution. It is very stange considering, it seems a very common need, maybe Im missing something, but I dont know where else to look.
Also my dream would be if I could create a new virtual button on the QGroundControl to be able to set exact pwm values in % to be able to contorl the motor RPM, via one of the aux outputs. Is there a way to create new, touch buttons to control one of the many free channels?
The config is a hexa, with Cube orange, standard carrier board, herelink.
Thanks a lot for any help, It would mean a lot, if somebody could help me out.
thanks!!
Well, i figured out that in Solex I can do that. If i configure a button to ch9 it will send the set PWM to aux1. But this way it is only working in Solex, but I need the QGC. Also it would be amazing if I could set the exact PWM output easily (like with a touch butto on screen) in QGC and than use the CAM button to turn the presert PWM value on the AUS out. Is it even possible?
I’m facing the same problem, I think the solution is in qgc customizing. And play in the code of QGC to create this virtual joystick. But did you solve it?
