pixhawk 1
MP 3.1.8
i want run 2 servo motor manually thorough MP
i tried but it not working
with best regards
That’s not enough information for much help other than some wild guesses. A common mistake is assuming the servo rail is powered on the older pixhawks. It isn’t, and you must supply power (often from the BEC) to the servo rail.
You can also do some reading in the wiki regarding the basics of configuration and setup.
i prepare the power for servo motor
just i want to run servo manually
all connection are ok but how can t tried the servo
How did you configure the SERVOx_FUNCTION parameter?
