How to change the Mission Planner files folder for OneDrive sync?
I use MS OneDrive across some computers. The Mission Planner folders in the “My Documents” folder make lots of synchronization errors, and the OneDrive option to do not synchronize it does not help.
Is there a safe way to change not only the logs path in the configuration menu but all MP files (mainly the .xml files)? Maybe a registry key?
Cheers
Any tips/thoughts @Michael_Oborne?
It is not possible without modifying the code at this moment.
Oh. Ok
Thanks you. :slight_smile:
