Hi all,
I am using 2 RFD868x-EU and MatekH743 Slim V3 controller with the latest stable plane firmware (4.4.4).
I managed to setup a link with the default configurations (both ardupilot firmware and modems firmware). However the rate is very slow, in particular I achieve about ~1 kB/sec which under EU restrictions (max duty cycle 10%) seems reasonable. I also saw here that others face the same issue. So at least I tried to increase the baudrate from 57600 (default) to 115200. Unfortunately did not see much improvement. To do so I made the following changes:
- Serial1_baudrate → 115
- changed modems baudrate using rfdtools to 115200.
- changed the ftdi cable baudrate to 115200 in device manager.
Am I missing anything? Shouldnt I be able to see the rate doubling approximately?
