The purple ground track is hard to see against some terrains, is there a way to change the color of the path the plane has already tracked over the ground ??? I see an option to change the length of this, but can not find a way to change the color.
Thanks for the answer. And thank you for the work you do on Mission Planner, it is a really great program, and all I use for flying. It has many things I never even knew I wanted !!!
